Looking for any helpful suggestions, debugging advice, how to proceed regarding my leaking washing machine.
About 2 months ago I had water on the floor in my basement utility room. This occurred during a very strong rainstorm/hurricane leftovers. Have had problems with that b4 in the past so I figured that is what it was. But the way the puddle seemed to stretch from where my washing machine was had me wondering.....that was atypical of where water has gotten in b4.....I had been doing wash at the same time so that was a possibility but I could see no evidence of where water might have come from the machine (it had already finished running by the time I saw the water).
Next time I did some wash I made sure to check the washer the entire time. Saw no leaks. And have run it about 12-15 times since then. No problems. 4got all about the water issue until this week....
I did some wash 2 days ago - 2 loads. 1st load went fine and was in the dryer. Started 2nd load in the washer. Happened to go into the room a few minutes later and saw puddle moving rapidly across the floor from the washer. It was still in the fill cycle. Looking around I could see that the water was coming from the top left had side of the washer (if facing it). Turning the fill off stopped the water coming out of the top side on the left. Turning it back on it immediately started leaking again.
Have not tried to use it since but suspect it is either an intermittent problem, or one that has gotten worse, suggesting some kind of valve, line leaking where it should not etc, as opposed to a leaking seal but I could be wrong.
I want to find out how to figure out what the problem is b4 I decide to give up and buy a new one, who knows maybe this is an ez fix. But I need to take the top off to look in there but can't figure out how to do it. So #1 is how do I get the top off to look inside fully around the drum? I can't see that with the top on.
The washer is a Maytag LAT8640. I bought it brand new when I moved here many years ago (28 years now). The dryer that I bought at the same time has had some issues but I have been able to fix it every time & it is still kicking. Maybe it is just time to bite the proverbial bullet and replace them both but I'd like to see if this is fixable first.
Any advice from you pros ?? Thx a ton and Happy Holidaze to all reading this.
