This could be a plumbing question, but it stems directly from hooking a portable appliance up to your sink:
If you don't have the option of hooking up to the hot and cold water sources separately, the alternative is to hook up to the sink's one spout. Works fine, till the appliance stops taking on water. Then, with the spout effectively capped, what's to prevent the hot running into the cold water supply, or vice versa, depending on which happens to have more pressure?
Assuming this is the case, I've always opened only the hot faucet or only the cold. Am I being overly cautious?
