water softener; salt calculation
  • FatimaandAhmed
    replied
    To determine if your salt usage is reasonable, let's break down the information and do some calculations:
    Given:
    - Water hardness: 26 gpg (grains per gallon)
    - Salt usage: 6 bags of 40 lbs each per month = 240 lbs per month
    - Each regeneration cycle delivers 700 gallons of softened water
    Step 1: Calculate the amount of hardness removed per regeneration cycle.
    Hardness removed = Water delivered × Hardness
    Hardness removed = 700 gallons × 26 gpg = 18,200 grains
    Step 2: Estimate salt usage per regeneration.
    A typical efficient water softener uses about 0.25-0.4 lbs of salt per 1000 grains of hardness removed.
    Let's use 0.3 lbs per 1000 grains as an average.
    Salt per regeneration = (18,200 grains ÷ 1000) × 0.3 lbs = 5.46 lbs
    Step 3: Calculate the number of regenerations per month.
    Regenerations per month = Monthly salt usage ÷ Salt per regeneration
    Regenerations per month = 240 lbs ÷ 5.46 lbs = 43.95 (let's round to 44)
    Step 4: Calculate total water softened per month.
    Water softened = Regenerations × Water per regeneration
    Water softened = 44 × 700 gallons = 30,800 gallons per month
    This amount seems reasonable for a household, especially if you have high water usage or a large family.
    Conclusion:
    Given the high hardness of your water (26 gpg is considered very hard), your salt usage appears to be within a reasonable range. The calculations show that your softener is regenerating frequently, which is expected with very hard water.
    However, if you want to optimize your system:
    1. Check if your softener is set to regenerate based on water usage rather than on a fixed schedule.
    2. Ensure the softener is sized correctly for your household's water usage and hardness level.
    3. Consider having a professional service check the efficiency of your softener.
    Would you like me to explain any part of this calculation in more detail?​
  • norton101
    started a topic water softener; salt calculation
    Is this salt use reasonable? The water hardness is 26 gpg. I use 6, 40#, bags a month. Each charge delivers 700 gallons of water.
