Tips to extend the life of Refrigerators
  • TinyTool
    • 357
    1. **Clean the Coils:** Every 6-12 months, dust off the coils at the back or underneath to keep your fridge running smoothly.
    2. **Check Door Seals:** Regularly inspect and clean the rubber seals to make sure they’re not cracked or worn out.
    3. **Keep Temps Right:** Set your fridge to 40°F (4°C) and your freezer to 0°F (-18°C) to keep food fresh and avoid overworking the appliance.
    4. **Organize Interior:** Don’t overcrowd your fridge. It helps with airflow and keeps everything evenly cooled.
    5. **Clean the Drip Pan:** Every 6-12 months, give the drip pan a clean to prevent odors and mold.
    6. **Defrost When Needed:** If you notice a lot of frost buildup, defrost your freezer to keep it working efficiently.
    7. **Ensure Airflow:** Keep vents inside the fridge clear to let the cool air circulate properly.
    8. **Level the Fridge:** Make sure your fridge is level so it doesn’t vibrate too much or have door-sealing issues.
    9. **Minimize Door Opening:** Try to open the door less often and keep it open for shorter times to maintain a steady temperature.
    10. **Check for Leaks:** Look for any leaks or puddles and fix them quickly to avoid damage.
    11. **Use Wisely:** Don’t put hot food directly into the fridge; it can raise the temperature inside.
    12. **Professional Check-Up:** Every 1-2 years, get a pro to check your fridge to catch any issues early.
    These simple steps can help keep your fridge running smoothly and last longer!​
  • Downaski
    • 409
    Hi.. Thanks for sharing this..
