GE Profile Series Built-In Double Convection Wall Oven inaccurate temperature.
  • machinist
    Moderator
    • 386
    Hi!
    If your GE Profile Series Built-In Double Convection Wall Oven isn’t heating to the right temperature, it can be frustrating, especially when your meals come out overcooked or undercooked. There are a few common reasons this might happen, and luckily, some of them are easy to check yourself. One of the most common issues is a faulty temperature sensor, which monitors the heat inside the oven. If the sensor isn’t working right, it can send the wrong signals to the oven's control board, leading to inaccurate temperatures. Sometimes, the sensor might just be misaligned and touching the oven walls, which can mess up the readings. If that’s the case, realigning or replacing it could solve the problem.
    Another possibility is that one of the heating elements is faulty. In convection ovens like this one, both the bake and broil elements need to work together to maintain the right temperature. If one of them is damaged, the oven won’t heat evenly. A quick visual inspection of the elements can reveal if one needs replacing. If you’re unsure, using an oven thermometer can help you double-check the temperature.
    Sometimes, the issue is simply calibration. Over time, your oven’s temperature settings can drift a little. Fortunately, you can usually recalibrate the oven through its settings by adjusting the temperature up or down by a few degrees. Check the manual for instructions on how to do that—it’s often a quick and simple fix. If that doesn’t help, or if your oven’s control board is malfunctioning, a reset by turning off the power at the breaker might fix any glitches.
    Lastly, if you’re using convection mode and the temperature is off, it could be due to the convection fan not circulating air properly. If you notice uneven cooking, it’s worth checking whether the fan is working. If all else fails and the problem persists, it might be time to call in a professional to inspect the control board or other components.
    Hope this helps!​
