Air fryer
  • Alpha
    • 194
    Air fryer
    Hi everyone! I'm thinking about getting an air fryer and wanted to see if it's really worth it. Do they make a big difference in cooking, and how do they compare to an oven when it comes to power usage? Do they use a lot of electricity, or are they pretty efficient? I'd love to hear your thoughts. Thanks in advance!
  • machinist
    Moderator
    • 386
    Hi! An air fryer can definitely be worth it, depending on your cooking needs. They cook food faster than an oven and can give that crispy texture without using much oil. As for power usage, air fryers are generally more energy-efficient than ovens since they preheat quickly and cook food in less time, using less electricity, which can be a bonus if you’re looking to save energy.
    However, the capacity is smaller compared to an oven, so if you're cooking for a large group, you might need to do multiple batches.
    • Alpha
      • 194
      Thanks for the helpful overview! I'm really curious about how air fryers actually work - what's the technology behind them? And while you mentioned they use less oil, I'd love to hear more about whether they actually make food healthier compared to traditional frying.
      • machinist
        Moderator
        • 386
        Air fryers work by blasting hot air around the food at high speeds, kind of like a mini convection oven. This rapid air circulation makes the outside crispy, similar to deep frying, but without needing a ton of oil. Instead of submerging food in oil, the hot air does all the work, giving you that crunchy texture with much less fat.
        As for whether they make food healthier, yes, they do compared to deep frying. Since air fryers use little to no oil, they can cut down fat and calories by up to 70–80%. That means you can enjoy crispy fries or chicken with much less grease. But keep in mind, it still depends on what you’re cooking. Air-fried veggies are great, but processed frozen foods (even if air-fried) can still be high in sodium and additives.
        So, air fryers are definitely a healthier alternative to deep frying, but it’s still best to eat a good mix of fresh foods.
        • FatimaandAhmed
          • 343
          Hi Alpha and Machinist, interesting topic! Machinist, do you know if an air fryer generates a lot of heat in the kitchen, or is it more contained compared to an oven? Also, do air fryers tend to have any issues with durability over time?
          • machinist
            Moderator
            • 386
            Hi!
            Air fryers don’t generate as much heat as an oven since they are smaller and use rapid convection to cook food efficiently. Most of the heat stays contained inside, so they won’t warm up the kitchen significantly. However, they do release some warmth, but it’s minimal compared to an oven.
            In terms of durability, air fryers can last several years, but common issues include the fan or heating element wearing out, the nonstick coating on the basket peeling over time (especially with frequent scrubbing), and occasional electrical problems. Higher-quality models tend to be more reliable, and regular maintenance, like cleaning and avoiding overheating, helps extend their lifespan.
            • EliezerCarroll
              • Oct 2024
              • 8
              Air fryers are definitely worth it if you enjoy crispy, quick-cooking meals with less oil. They cook faster than conventional ovens due to their compact size and rapid air circulation, which can save time and energy. In terms of power usage, most air fryers use between 1,200 to 1,800 watts, which is comparable to or even lower than an oven running for the same cooking duration. Since air fryers preheat quickly and cook food faster, they often use less electricity overall than a full-sized oven. If you frequently cook small portions, an air fryer can be a more efficient option. However, if you're cooking for a large family, an oven may still be more practical. Would you be using it for specific foods or just general cooking?​
              • Alpha
                • 194
                Thanks so much for all the help, Machinist! Really appreciate it. Can you also explain what to look for in a good air fryer to make sure it lasts? And do you have any brand recommendations for something reliable?
                • machinist
                  Moderator
                  • 386
                  The most important things to look for in a good air fryer are build quality, heating power, size, and ease of cleaning. Choose one with a stainless steel or sturdy plastic body and a high-quality nonstick basket to prevent peeling. A higher wattage (1500W or more) ensures faster, even cooking. Pick a size that fits your needs, smaller for individuals and larger for families, so you don’t overload it. Easy cleaning is a must, so a dishwasher-safe basket is a plus. Digital controls with manual temperature settings give better control than just presets. Stick with reliable brands like Cuisinart, Breville, or Ninja for better longevity and support.
                  • Annahmed
                    • 223
                    Great discussion here! I've been on the fence about getting an air fryer, but all this talk about efficiency and crispy food with less oil is really tempting. How noisy are they, though? Do they get loud?
                    • machinist
                      Moderator
                      • 386
                      It’s great that you’re considering an air fryer! In terms of noise, most air fryers do make some sound, but it’s usually comparable to a microwave or a small countertop fan. The noise mainly comes from the fan that circulates hot air, and while some models are quieter than others, it's generally not loud enough to be disruptive. If you're used to a regular convection oven or a range hood running, it’s about the same level of background noise. That said, if you're particularly sensitive to sound, you might want to check reviews on specific models, as some high-powered ones can have a noticeable hum. But overall, the noise isn’t a dealbreaker for most people.
                      • Annahmed
                        • 223
                        Thanks! It’s good to know the noise isn’t too disruptive.
