Is your washing machine taking an eternity to fill up with water? It's a real annoyance, particularly when you don't have much time to waste. Most often, the problem lies in a faulty valve or a component that's not performing at its best. If you're experiencing this issue, the time has come to call in the professionals. For reliable Washing Machine Repair in Calicut, diagnosing and repairing issues with water flow is just a phone call away. Knowing the most common causes can assist you in knowing when to have expert service.
Common Valve Problems That May Cause Delayed Filling
If you have a washer that is too slow to fill, it's advisable to let a professional diagnose and repair it. Fixail provides professional washing machine repair in Calicut with expertise in fixing problems with water inlet valves and other components. Contact us for a speedy and effective repair to get your washing machine back to normal.
- Water Inlet Valve Failure: The water inlet valve regulates the flow of water into the washing machine. When this valve is clogged with mineral buildup or debris, it can limit the flow of water, making the machine take longer to fill. In other instances, the valve can be faulty and not open completely, extending the filling time.
- Faulty Solenoid Coil: The coil within the water inlet valve solenoid governs the closing and opening of the valve. When the coil is faulty or worn out, the valve will not work normally. This will cause a delayed filling cycle because the valve won't open wide when it must. Replacing the solenoid coil typically fixes this.
- Dirty or Clogged Filters: In other cases, the problem lies not with the valve but with the water filters. With use over time, the filter screen gets clogged by debris, lint, or mineral deposits, restricting the amount of water entering the machine. This can be avoided by cleaning the filters regularly.
- Low Water Pressure: Slow filling can also be caused by low water pressure in your house. If the water pressure in your area is too low, your washing machine will not be able to fill up fast. Check your home's water pressure and make sure it is enough to support your washing machine.
