Your TV may appear to be alright on the exterior, but unseen threats may quietly be harming it from the inside. Most individuals go for TV Repair in Kozhikode only after their screens become black or speakers cease to function, but at that point, the issue has already occurred over time. The following are five silent perpetrators that may reduce your TV's lifespan without you even realizing it.
1. Power Surges
Sudden voltage surges can burn internal circuits in your television, particularly where voltage is unstable. Even a single high surge will permanently damage. A surge protector will protect you against expensive repairs or replacements.
2. Bad Ventilation and Overheating
Your TV requires adequate airflow to work effectively. When it's too close to walls or in cramped cabinets, the retained heat will damage components over time. Ensure there's sufficient space for the heat to ventilate, and don't block ventilation ports.
3. Dust Buildup
Dust may seem harmless, but it can accumulate inside your TV’s vents and on its circuit boards. This buildup restricts airflow, contributes to overheating, and can even cause short circuits. Periodic dusting and keeping your TV area clean can make a big difference.
4. Leaving the TV On for Too Long
Longer use hours or not switching off the TV can decrease screen life, particularly for LED and OLED screens. Screen burn-in, picture retention, or backlight problems are typical in continuously running TVs. Utilize energy-saving features and auto-off schedules to maintain screen quality.
5. Improper Wall Mounting
Poorly installed TVs are subject to stress on internal components by angle, tilt, or instability. Always adhere to the manufacturer's instructions or have a professional install your TV correctly and safely.
Conclusion
Steer clear of these hidden dangers and prolong the life of your television with smart maintenance. And if your TV already displays signs of damage, Fixail can assist you. We provide professional TV Repair in Kozhikode, quick service, transparent pricing, and certified engineers. Whether it is a quiet problem or a sudden failure, Fixail has your screen protected. Book your repair today with confidence!
1. Power Surges
3. Dust Buildup
Conclusion
