Onkyo integra t-890 tuner amplifier
  • Trainmaster
    • Oct 2011
    Can anyone help? This is a strange problem.
    My Onkyo Integra T-890 powers up fine, but when I push a "speaker selector button "A" or "B," the unit shuts down for a second, comes on again if the button is still pressed, and then repeats the shutting down.
    It will stay on with no problem if the speaker buttons are not pressed. I even disconnected the speaker connections and tried it. The problem still existed.
    Sometimes, when the unit has been on for a while, it will eventually work, sometimes not.
    The headphone jack works fine.
    Does anyone have a clue as to what the problem may be? I doubt if it is the power supply because they either work or not.
    Any suggestions - I am desperate for help!
    Trainmaster
  • valveradio
    • May 2010
    • 19
    amplifiers can be weird things lol. it sounds like your output stage is ok. maybe the speaker switches need a clean or possibly they may have a dry joint on them assuming they are connected directly to the main p.c.b.
    other than that it could be a bad connection somewhere and the act of pressing the speaker switch is flexing the pcb somehow.
    whatever it is, doesnt sound serious.
    regards, peter
