Mounting a plasma TV
  • mmgirl
    • Mar 2005
    I'm about to put up a plasma tv above a fireplace. The house was built in 1948 so the fireplace must be brick and plaster. Any advice on how to install the mount properly and securely in plaster and brick?
    Thanks!
    • 8747
    How much space do you have behind the wall and the brickwork? Is there a bracket that the TV sets on? Easiest way for blind fastening is with 1/4 inch toggle bolts
    • mmgirl
      • Mar 2005
      Not sure how much space behind wall till brickwork. How would I find out? I bought a mounting kit but I am going to attempt to install it myself. Just wondering if there were any special things to do in a situation like mine.
      Thanks
        • 8747
