A tape got stuck in my TV/VCR, so I forced it out. Now when I turn teh TV on, it will rewind, then stop and try to eject, but there is no cassette in the VCR. How do I get the VCR to stop doing this?
VCR rewind+eject broken
Tags: None
the tape jam has caused the vcr to think the cage is still loaded. the machine stilll thinks a tape is inside of the unit. you will need to reset the vcr part. you will have to open the tv cover to reset the vcr. i would not recomend you doing this yourself. the tv will probably keep shuting off on you till it is repaired... -
inside the unit, when a cassette is inserted the carriage moves along two guides that drop the cassette down to the tape transport mechanism. there is a hole in the cartridge about center that drops down over the IR sensor. This sensor detects the presence of the tape and cartridge. if the "tower" is bent or broken it gives the signal that there's no tape and ejects the cartridge. it is a retroreflective infrared transistor and pickup. no voltage to it is just like no tape detection.Comment
