Old Fisher amp crackling in left channel
  • carcinogen
    • Nov 2007
    I'd like to save this unit as it has fairly good sound quality and I'm flat broke. I use it to amp a phono and computer input out to a pair of 150w speakers. It's a Fisher CA-854.
    A couple of months ago, I had this crackling/distortion in the right output channel. Sounds like a blown speaker. It is independent of the volume setting and seemed to be proportional to mid range sounds. It was an intermittent problem that would go away for about 5/10 mins if I turned the amp volume all the way up and played some music for a second. Then I grounded the unit and it went away completely, until now.
    Now, there's the same crackling/distortion in the left output channel! It's independent of the speakers (as was before - switched the wires) and has the same "temporary" fix (a good bass beat at full volume will make it go away temporarily).
    I'm thinking some kind of corroded connection, but I've poked around inside and I haven't seen anything out of the ordinary, besides some corrosion on the output fuses. Didn't fix it.
    Does anyone have any ideas? The problem occurs regardless of inputs (aux or phono produces same results) or A vs B channel outputs.
    TIA
    the way a speaker is constructed, you have the frame which supports everything. on the back is a permanent magnet of varying gauss. on the frame is a magnet pole piece which is a solid rod. glued to the surface is a mesh spider which centers the voice coil around this rod magnet. the voice coil consists of a fine wire wound around it. it is terminated in a braided wire jumper which goes to the terminals. a dust cover is glued to the baffle front which keeps stuff out of the air gap of the magnet - voice coil. the baffle is a composite paper which forms the cone of the speaker. this is glued to the out side of the frame. when a varying frequency voltage is applied the coil is energized and moves in or out around the voice coil. this movement in and out is what produces sound. if the voice coil is rubbing ANYWHERE on the magnet it will cause distortion. varying temperatures and humidity will expand the voice coil form and cause rubbing. mishandling might disrupt the spider and mis align the voice coil. when a speaker "blows" the voice coil burns out - it opens. some windings might weld themselves together changing the impedance of the speaker and cause rubbing on the magnet piece. turning up the bass temporarily fixed it by moving the voice coil over a large range of frequency but will return to "normal." I don't think your amp is at fault I'd look to the speakers.
    • carcinogen
      • Nov 2007
      I took your advice and fetched another pair of (75w, good condition) speakers from the basement. I even ran some new wire. Same problem! Just the left channel!
      What the heck is going on?
      • carcinogen
        • Nov 2007
        So, I just got a nice static electricity shock from the receiver (yes, it's still grounded, even!!) and the crackling went away, again for only a couple of minutes. Does this have something to do with a poorly grounded transformer or something like that, perhaps? Since I don't know my way around the inside of an amp, can someone point me to any possible culprits?
          I'm not familiar with your amplifier in particular however if it uses tubes, then what you may be feeling [as far as shocks] go is the B+ voltage on the plates of the tubes. This voltage can be as high as 180 volts DC or higher!. The tube filaments operate at around 6.3 volts. AC is fed from the line into a filament and B+ transformer where it is stepped up and down for its use within the system. It is then fed to a bridge rectifier which changes the AC to DC. A dual diode tube is what changes the AC to DC. Everything in the circuit except for the power supply capacitors should be running "above" ground. The negative of the filtering capacitors are grounded to the case. Essentially everything metal is grounded to the case. If the transformer shorts out or part of its winding shorts to ground it will charge the case to line voltage [ which is dangerous] if you are grounded. there are other components of tube systems which can contribute to your problem. the control grid has a DC voltage on it to vary the amount of electrons that are given off by the filament from reaching the plate which is how a tube can amplify. there's other parts too - a suppression grid etc within the tube.
          A leaky filter capacitor can contribute to extraneous sound or crackle.
          • MRismydog
            • Apr 2010
            Same Problem
            I have the same amp with the same problem. Just the left channel, nothing to do with the speakers. Grounded to the light socket behind amp but problem occurs whether or not it is grounded. Will clear up if you tap around on the amp. Any help in laymen terms?
              look for something loose. cold solder joint.
              • sam999
                • Aug 2008
                • 17
                I had the same issue with an older amp and it was only on the left channel as well.
                My amp was an old techniques unit but it was a faulty knob on the amp. If you fiddle with the balance does it cut-in/out?
                I found I could temporarily fix it with compressed air blasts but it would always get dirty again and I eventually gave it to a friend who replaced the whole mechanism with a spare.
                • valveradio
                  • May 2010
                  • 19
                  fisher amp
                  hi. it sounds very much like a loose connection to me. are your speakers sited near the amp or well away from it? if they are well away then it makes sense that the noise doesnt come on at high volumes, if they are close however you would expect the vibrations of the speakers to to make the noise worse as the volume was turned up. as the fault (if i remember rightly) was previously not on the left channel solely i would be looking at possble dry joints around the power supply, output stage and any plugs and sockets that were connected to the pcb(s). also check your phono sockets on the rear to see if they are dry jointed as sometimes they are connected to the main pcb and tend to work loose over time.
                  good luck!!!
                  peter
