Multimedia, Multi-rooms
  • NPBSurfr
    • Jun 2010
    So, here’s what I have, I want speakers in at least 3 – 6 separate rooms, all to work independently or at least disable or enable rooms at will from a radio (long range of up to 75ft) remote control, and have it work with MP3s from a server. I’m already setting up the house with CAT6 wires so I’m setting up each TV to work with Windows MCE and getting the Ceton Tuner for cable. Then having each entertainment/TV have a bookshelf PC to run Windows MCE indepentantly.
    Is this the best bet for what I’m thinking?
  • Sensible
    • Oct 2010
    • 24
    Sorry, you question is way out of my technical league, but I'm curious... will your plan require "at least 3-6" separate Windows licenses?
      you'll need to consider the speaker impedances. most are 8 ohm but when you start to series them or parallel them [even with a crossover] the ohmic impedance changes. a mis-match with your system will burn out something.
