vcr samsung sv-5000w sparks
  • herrmann
    • Sep 2010
    Sirs, my vcr samsung sv-5000w show some white sparks, during the normal playing of videocassettes, I cleaned the heads accurately, but without a solution... Perhaps electrical contacts ? I thank you in advance for your help and, please, sorry for my english. HERRMANN.
    • 8747
    the playback head in a vcr is angled off center. it consistes of two magnetic heads located at the top and bottom of the polished head, 180 degrees apart. when the tape is pulled across the head the tape head reads across about a three inch strip of tape at any given time. raster on your tv screen depends on tape head speed and the electronics that generate the re-trace of your picture tube. the tape must be spotless the tape head must be spotless. if the tape head looks dull it will destroy your tapes.
    • herrmann
      • Sep 2010
      Thanks for the reply, hayzee.
      Thank you very much, for your explanatio !
      • herrmann
        • Sep 2010
        the sparks continue in spite on the cleaned heads
        Help sirs, i continue to see white sparks during the play with vcr sv-5000w samsung.
        The sparks change when i open the vcr or i touche it with some screwdriver. Perhaps i need an exorcist ?
        Thanks a lot for your patience, herrmann
