We have laminate countertops throughout our house. On two of them we have noticed they are either delaminating or are no longer glued to the substrate. The house was built in '92.
Many years ago I worked a little bit (very little) with some laminate and it was attached with a hot glue, so you just used an iron on the laminate and it melted the glue & it stuck.
Suppose I can use an iron to get these countertops to stick again? Is theat the standard way to attach laminate? If so, what setting should I use?
Is there any other fix?
Thanks for any help. We sure don't want to replace the countertops.
