Adding Ventilation to an interior door
  • goerinjd
    • Oct 2007
    I need to either add ventilation to an interior door or replace it with a louver door. it is the door that leads to the utility room where the HVAC unit is. Ideally I would like to be able to cut out the lower panels and add in some type of ventilation.
    I am a novice and am not sure how to go about doing this. Is it even possible?
    Any suggestions or “how to” instructions would be extremely helpful.
  • Blackhawk
    • Nov 2005
    • 35
    You mention that the HVAC unit is in the utility room. Does the HVAC unit have a return duct already attached to the living space? If yes, the HVAC unit should not need any further venting.
    If no, I would go with a louvered door. Since you said "panels", I assume that the existing door has 4 or 6 raised panels in its construction. You could get these out, but whatever type of vent or grille that you insert would not look good.
      In almost all cases now a utility room with HVAC must have vented doors.
      If it were me I'd replace the existing doors with louvered doors that are available at most big box stores.
