How to cut shelving around pipe
  • jdl
    • Aug 2008
    Hey guys,
    A friend of mine has a shelving unit built into a wall. He says that it is made of oak or a wood similar to oak. It is built with a water pipe going through the middle. He said that the problem is in the winter, the pipe expands and makes a horrible creaking sound when it is pressing against the shelving.
    Would the best way to remedy this be to cut out a bit more around the shelving? If so, what kind of handsaw (or other tool) should i use?
    Thanks!
    a jigsaw will fit the bill. just open up the opening a bit.
      Squeaking pipe
      Lay a small amount of talcum powder between the pipe and wood. It may lubricate it enough to save a lot of work.
        Drill a small hole and use a coping saw (undo he blade insert it in the hole and re attach the blade)
