Hole in Cabinet Door
  • barryman9000
    • Jan 2010
    I was installing "Tot Lock" baby proofing door locks on one of our kitchen cabinets and I drilled a hole through the cabinet. Now there is a 9/32" inch hole through the wooden door.
    Is there anything I can do to repair it, or will I have to replace the door? Any help/suggestion is appreciated
    You can various colors of hole filler at big box stores, if your unsure about the color match take the door with you.
    • lostinit
      • May 2010
      I have the same issue. Will the putty be able to prevent the pin from sticking to it when the magnetic lok is engaged?
