Best types of wood for building kitchen cabinets
  • Downaski
    • 409
    Hello everyone! What are the best types of wood for building durable, long-lasting kitchen cabinets? It’s important to choose wood that holds up well to moisture and daily wear, but also looks great. What finishes are recommended to protect the wood and keep it looking good over time?
  • FatimaandAhmed
    • 343
    Hi Downaski!
    For durable and long-lasting kitchen cabinets, hardwoods like maple, oak, cherry, and birch are excellent choices. Maple is strong and has a smooth grain, making it perfect for a clean, modern look. Oak is highly durable and has a beautiful, prominent grain that works well in traditional or rustic kitchens. Cherry wood is another sturdy option, with a rich, warm color that deepens over time. Birch is a budget-friendly choice that still offers good durability and a subtle grain.
    To protect the wood from moisture and daily wear, use a high-quality finish like polyurethane, which creates a strong, water-resistant layer. Satin or semi-gloss finishes are popular for kitchens because they’re easy to clean and hide minor scratches or smudges. For an even more natural look, consider an oil-based finish like tung oil or Danish oil, but keep in mind these may require more frequent reapplication. Whatever finish you choose, make sure to seal all edges and joints to prevent moisture from seeping in and causing damage.
    Hope this helps!
    • Downaski
      • 409
      Thank you. What’s your take on engineered wood or plywood for cabinets compared to solid hardwood? Are they worth considering?
      • FatimaandAhmed
        • 343
        Engineered wood and plywood are definitely worth considering for cabinets, especially if you’re looking for durability and budget-friendly options. Plywood is a great choice for cabinet boxes because it’s strong, resists warping, and handles moisture better than solid hardwood in many cases. High-quality plywood with multiple layers is sturdy enough to hold heavy items and is less likely to crack over time.
        Engineered wood, like MDF (medium-density fiberboard), is another good option for cabinet doors or panels. It’s smooth, which makes it perfect for painted finishes, and it doesn’t expand or contract as much with humidity changes. However, it’s not as durable as solid hardwood and can be prone to damage if exposed to water for long periods.
        If you love the look of hardwood but want to save some money, you can pair solid hardwood doors with plywood boxes. It’s a good balance of aesthetics and practicality. Just be sure to seal or finish any exposed edges of plywood or engineered wood to protect it from moisture and wear. Overall, they’re worth considering, especially if you choose high-quality materials and finishes.
        • Downaski
          • 409
          That makes a lot of sense! I didn’t realize plywood handles moisture better than solid hardwood. Do you think MDF would be a good choice for a bathroom vanity, or would plywood be better because of the moisture?
          • FatimaandAhmed
            • 343
            In a bathroom setting where moisture is a major concern, plywood is typically the better choice for a vanity compared to MDF. While MDF (Medium Density Fiberboard) is smooth and great for painted finishes, it’s not as moisture-resistant as plywood. MDF tends to swell and weaken if exposed to water over time, even if it’s sealed.
            Plywood, on the other hand, is constructed with layers of wood veneer, making it stronger and more stable in humid conditions. Its layered structure resists warping and handles moisture fluctuations better, especially when properly sealed or laminated. For a bathroom vanity, opt for a cabinet-grade plywood and ensure it’s finished with a waterproof sealant or laminate for added protection.
            If you’re set on MDF for its smooth finish, make sure it’s a moisture-resistant grade (like MR MDF) and fully sealed to protect against water damage. However, for long-term durability and peace of mind, plywood is the safer bet in a bathroom.
            • Downaski
              • 409
              Thanks a lot for the info! Appreciate your help!​
