While doing some kitchen repairs...new cabinets, some revised plumbing....I ran across this situation:
The water meter is located under the new cabinet but DIRECTLY where the new cabinet wall will be. There is a ground strap from one side of the meter to the other. What I would like to do is to merely swing the meter 180* to be directly under the cabinet making it accessible and easier to see/read. I will not be disconnecting the meter in any way. My issue is the house ground. I need to separate the plumbing from the meter on the house side. I FINALLY found what I believe to be the house ground. It was fed up from the crawl space through the wall and clamped to the cold water stub as it passes from the wall. In fact that wire is actually coming out of the same hole the stub pipe is. (Wierd, yes...) I would like to pull that ground back to the crawl space, and secure it to a more accessible pipe. So, should the house power (main) be switched off and then I can safely resecure it? Using ground rods is preffered, but I don't think I can manage that in the crawl space. Any suggestions?
