I could use some help with this strange problem we got yesterday..
I was changing out some of the valves of the sprinkler system and testing it. About 1 hr later, my wife tells me the laundry room light switch no longer work and the electrical outlets are not working in the library. The library and the laundry room share one wall.
It is strange to me since the outlets in the laundry room are working fine but the light switch is dead. The library light switch is working fine but the outlets are dead..
As I mentioned earlier, the library and laundry room share one wall.
I checked all the breakers and reset it but the problem remains. I used a multimeter on the breakers and the voltage readings are good.
the house was built in 2005 so it is not that old. I am trying to see if the builder has the electrical diagram but I highly doubt that.
as i continue to investigate, I found out that the light switch is on the same circuit as my outdoor and entry way. The outlets in the laundry room are on its own circuit per label of the electrical panel.
I really could use some suggestions on where to start this investigation.
