There should be a name plate on these motors with amps, volts etc stamped on it. I would look for that first, cause they may pull more than 10 amps and that may be what scrambled his meter.
Checking for watts...or amps...
Looks like this meter will do the job???
Digital Clamp MeterMark
Owner of 1 house (3200 SQ.FT., 4 car garage)
Owner of 3 rental houses (partner with the bank.)
the waste oil heater he's fooling with uses a source of compressed air to atomize the oil. the waste oil goes through a pre-heater to make it flow easier. the burner is a standard oil burner with a fan and gear pump and 60 degree fuel nozzle. the nozzle doesn't use a bronze filter element because the heater pumps and burns waste oil into a heat exchanger. the air surrounding the heat exchanger is blown into the room by a fan.
Ah... heaters. I must have missed that. I thought he was testing motors of some sort. There is a possibility that these heaters might pull more than a small motor. Finding a data plate for them might be a bit tougher than it would be on a motor.
If the pre-heater is a tubular heater, the shell is called INCALLOY which an alloy of nickel and copper. with repeated heating the stamped value on the heater wears off then all that's left is to take an amp reading with a clamp around and calculate the wattage with voltage.
If we know how big the motor (for the compressor) is, we should get an idea of Anp. draw.
Amp Draw of Electric Motors
(Please keep in mind that every one of these I've used is low, it doesn't account for control Amp/draw. etc. (obviously.))
I would just use it for a Guide.
You shouldn't use a 20amp breaker for a 1 1/2hp motor runnning 120V (the motor alone is rated at 20amps, take in control amps etc. and I'm sure you'll be over.Mark
Yes, well kinda. You said Harbor Frieght (which is good for him $$$.) I'm just pointing out a meter (being more specific - he probably doesn't need it but, it's there.)Mark
Sorry, I thought he was looking for the amp draw of the atomizing compressor?
Originally posted by HayZee518 View PostHey You! What in Holy Heck does the motor have to do with the oil pre-heater????????? Not a dam thing! Read the posting. Bob is looking for the wattage of the pre-heater! NOT THE MOTOR. And further, there is NO compressor on the heater!Mark
