Bad hum on land line, but phones + line work fine otherwise. Disconnected all phones + then reconnected 1 at a time. Each phone still had the hum.
Took working corded phone to NID (outside box) + opened consumer side. Disconnected line from jack + connected phone in order to check on the hum.
No dial tone! Called phone number w/ cell. No RING! Disconnected phone. Connected line back to jack. Closed box.
Went back inside. Connected same phone again inside. Called land line number w/ cell. "Test" land line phone RANG!
Repeated process. Same result.
What gives? The phone rings inside, but not at the NID. And the line insider works if I plug it in back in at the NID.
In the meantime, I can't test the incoming signal for hum if I don't even get a dial tone at the NID.
