About a month ago the lights started flickering in 4 rooms exept 2 and it will still do it with no appliances on. I turn off the lights and use a lamp an all the outlets from those 4 rooms and had the same problem, then about a week ago the power went on and off every day in those 4 rooms specially at night .The breakers stay on ...we change 2 breakers to see if that was the problem but nothing changed..The other 2 rooms don't seem to have any problem..Any ideas?....why don't the breakers flip? ..
edith
edith
!!ok i call the power company they are going to send someone...but if the problem was outside ,Why don't the other 2 room have the same problem[?] ..this is an 80's movil home so we are going to check every outlet and connection, Do you thik the problem could come from there[?]
