Recently my hot water heater died. Upon checking the secondary breaker box in a small shed next to the house, I noticed that the box was extremely rusted due to a hole in the roof that exposed it to the elements. It is a Bryant Enclosure (Box!) The main breaker panel in my house is a Crouse Hinds. So I thought I'd get a Crouse Hinds to replace the rusty bryant. I did a little research on the web. A little research turned into a lot of research as I tried to track down a box. Why can't people make up their mind on what the metal box that encloses the breakers is called. Is it a "load center" a "breaker panel" an "electrical panel" a "fuse box" a "fuse panel" a "fuse board"..... the list goes on. Arrrgh!
At any rate, I learned that Crouse Hinds is now owned by Cooper, and yet although you can find some Crouse Hind individual breakers on the web, the "load center box" itself is incognito. Now it seems that Crouse Hinds are also referred to as Murray breakers, or to cloud the already murky situation further "Murray/Crouse Hind" breakers. Now I have read a favourable review of Crouse Hind breakers. And yet I have also read a review of Murray panels that stated the panels were dangerously problematic. How does Crouse fit in to that? What on earth is going on here?
Is this subject worth persuing any more, or should I just run out and buy a Square D panel and say to heck with Crouse and Murray et al. ???
I have seen too many of them where the buss-breaker connection heats up and melts, and even a few where the side of the 100A cutler hammer "BQL" bolt on style breaker have gotten so hot internally its burned the side right off the breaker!
