Helpful Electrical Drawings
This is a sticky topic.
  • Troy
    Moderator
    • Jul 2002
    • 576
    Wiring a three way light:
    credit goes to HayZee518!
    Try
    Try
  • Troy
    Moderator
    • Jul 2002
    • 576
    Electrical Receptacles:
    Try
    Try
    • Troy
      Moderator
      • Jul 2002
      • 576
      Fittings:
      Credit goes to HayZee518!
      Try
      Try
      • Troy
        Moderator
        • Jul 2002
        • 576
        Meter and Breaker Box:
        Try
        Try
          Circuit Breaker Images
            Garbage disposal
              You guys are good.
              • Kidd6488
                • 110
                Troy/Hayzee... No big deal, I was just confused while looking at those pictures and figured it out... On all the 125V outlets, (with ground down) hot (short) is on the right, and neutral (long) is on the left. And the (poor drawing :-) ):
                0
                is only 125 volt (20A), not 125/250, correct?
                Those 3-way drawings are very nice, and helpful!
                ~Jonathon Reinhart
                ~Jonathon Reinhart
                • Troy
                  Moderator
                  • Jul 2002
                  • 576
                  Doorbell - Credit to HayZee!
                  Try
                  Try
                  • Troy
                    Moderator
                    • Jul 2002
                    • 576
                    Fuses (Credit to HayZee!)
                    Try
                    Try
                    • Troy
                      Moderator
                      • Jul 2002
                      • 576
                      HayZee again!
                      Try
                      Try
                      • Troy
                        Moderator
                        • Jul 2002
                        • 576
                        Boxes:
                        Cover Plates:
                        Thanks HayZee!
                        Try
                        Try
                        • billg
                          • Jan 2006
                          • 6
                          Anyone have a drawing of wiring a series of outlets where the top is on a three way switch and the bottom is always hot?
                            billg - supply me with your email address - I'll send you a jpg image. The forum is restricting me to a file 39.1 Kb in size - the diagram I made up is 48.4 Kb in size.
                              bill send me your email addy - I'll get you a diagram
