Hello!
I haven't been on here in a LONG time but I have a quick question regarding a transformer or rather a group of transformers at my friend's metal fabrication shop.
What he has is 3 separate 15 KVA 600V - 120V dry type transformers wired in " Delta-Wye " to give him your typical 120/208V 3 phase 4 wire service. No problems there I understand that, BUT what I can't figure out is will that setup be considered to be equivalent to a " 15 KVA 3 phase" transformer, or a "45 KVA 3 phase" transformer.. I am just curious because if its going to behave like a " 15 KVA 3 phase " transformer, I believe its dangerously overloaded. If its going to be behaving like a "45 KVA 3 phase" transformer, all will be well as far as loading, the only thing that may be wrong would be a code violation regarding the secondary conductor size. He hasn't had any problems as of yet BUT last time I was there he just parked a small rooftop A/C up top and I want to know what I have to work with as far as what actual "size" his transformer bank really is before I hook anything up! ("small rooftop" being 20 amp @ 208V SINGLE phase)..
Thank you for any help anyone can provide!
A.D
A.D
