Electrical newbie here, please be patient as I try to explain my situation adequately.
I added recessed lights and a dimmer switch. Behind the old switch was an incoming power supply (two wire) and outgoing to a switch with three wire (black, white, red and ground). The red controlled one of the switches for a lamp.
The only way I could get the power to work in the room was to pigtail the red with the black wires at the switch. But now the power to the outlet in the room dims when I use the dimmer on the switch. Make sense????
What am I doing wrong? I would like to permanently disable the outlet being controlled by the switch. Is there a way to disable the red wire usage? Can I remove the red from the outlet and the switch and cap them both?
Thanks.
Thanks.
