wiring a ceiling fan with switch's for light and fan
I need someone to tell me how to wire in a ceiling fan using a switch for the light fixture and a switch for the fan. Please help with a drawing if possible.
Thank You
1) Do you have an existing fixture in the location that the proposed fan will be installed?
2) Is this fixture switched from a switch on the wall, or a pull cord.
If you just have one switch presently controlling your fixture then you'll need to install different wiring between the fan and the switch box if you want to control the fan and the light separetly. You'll need a 3 conductor cable for this.
And, if the power comes into the switch box first, then the following link will show you how to connect the switches and the fan/light.
This website is for sale! danswiringpage.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, danswiringpage.com has it all. We hope you find what you are searching for!
The breaker keeps tripping but only when I run the microwave AND the toaster at the same time, like clockwork every time. Is my house wiring dying? It's...
