Hunter Ceiling Fan Switch 27186
  • FUCO
    • Jan 2006
    If i hook this up to a two wire switch do I also have to hook up some type of receiver in the canopy of the fan? I just have the on off wall switch which turns on my lights and fan at the same time. i was under the impression that i needed three wires to run things independantly. What i have been reading so far about this it seems it will do what i want without running any additional lines/
    here is a link
  • kactuskid
    • Mar 2004
    • 801
    Fuco I have no experiance with the special switch you posted the link to, though by reading the description it doesn't sound like any other device is needed in order to control both functions independently. Must be some new fangled device that just came out. If you end up buying and installing this switch I'd be interested to know how it works for you. If it doesn't work you can always return it.
