I think I hurt something. I was swapping a normal switch for a dimmer switch. Then there were sparks. Now nothing in my house works. Even when I flip the main breaker everything stay dark.
So here's how it happened:
I replaced the normal switch. (now I have a normal switch and a dimmer switch side by side) The cover plate is in place on the dimmer switch and as I was putting the normal switch in position, a wire touched the metal box behind the drywall. That is when the spark happened.
Am I wrong in saying this happened because the wire touched the box? Maybe it was because of swapping the switches, I don't know.
If so, why is all of the power out in my house, and not just a blown fuse for my living room?
I am in the dark, but my neighbors are kind.
Thank you
Spencer
Thank you
Spencer
y
