Removing circuit breaker
  • zvidoron
    • Jul 2006
    I am trying to replace a 2-pole 30 amp. GE THQL circuit breaker in an Arrow Hart Murray load center. After turning off the main and disconnecting the wires, I tried pulling off the old breaker, but it doesn't budge. Any suggestions?
  • Snoonyb
    • Sep 2004
    • 127
    If the breakers are in two vertical rows, insert a narrow blade screwdriver between them, and use the other breaker as a fulcrum.
    If the breakers are in a single row, insert the screwdriver between the breaker above and below. Grab the breaker trip handle with a channel locks with the curved section facing to the right and bump it with the heel of your hand, to the left.
    When I say "insert", I mean, no more than 1/8".
    Illegitimas non-carborundum
    • zvidoron
      • Jul 2006
      Thanks - will try and let you know.
      • zvidoron
        • Jul 2006
        Thanks - it worked!
        • Snoonyb
          • Sep 2004
          • 127
          Anytime, Anytime, Anytime you wish to opine or share any tricks you've learned.
