Switch installation question
  • fordprefect
    • Aug 2006
    Hi everyone!
    First let me say that although I an electrical and computer engineering student (NTUA, Greece), I have been so focused in the "computer" part I have very little knowledge of electrology and even that is mostly theoretical. I do know how to use some very basic tools (multimeter, which I currently don't have, and, ahem, screwdriver) and once I put together a filter circuit that almost worked, but beyond that it wouldn't be exaggerating to say my only practical experience in such matters has been changing light bulbs.
    Now, my problem is this:
    I am currently staying in Chisinau, Moldova, which is a former Soviet Union country. In our kitchen there is a light as well as a ventilator. They are both controlled by what I believe was meant to be a common DPST switch.
    When I arrived there was only a hole in the wall with three identical (well, one is a bit longer but I doubt that's significant) white cables in it. The light was turned on by sticking your hand in and connecting two of these cables (the short ones, actually). If you wanted the ventilator to function you connected the third (long) cable as well.
    Not very safe, I thought, so with my limited knowledge I successfully (!) installed a two-button switch to control the light. I left out the third (long) cable, so the second button does nothing and there is now no way to turn on the ventilator.
    I now want to connect the third cable too and make the switch fully functional.
    This is my guess at what's going on inside the walls (maybe "neutral" and "hot" should be inversed):
    Connections AC and ABC have been tested and BC is also presumed to be safe.
    What I am concerned about and the reason why I am hesitating is this:
    I have no way of telling which cable is C (it is logical it should be the middle one, but is that a rule?) and which is A, so it is possible A and B could be accidentally connected.
    My question (finally!) is this:
    Is it safe to connect AB (or BC, remember I can't tell) and see what happens?
    If I understand correctly C is "hot" while A and B are "neutral" and you need two "hot" cables to get something wrong. In any case it seems to me there is no way to get a "wrongly" closed circuit. At worst I'll end up with an open circuit.
    Is this correct? Should I proceed through trial and error or should I get a multimeter and/or call a professional?
    Many thanks in advance and sorry for the long post!
    Your help is greatly appreciated!
    use a multimeter and check all leads to a good ground. in europe there is 220 volts to ground so make sure you are on the
    380 or 1000 volts measurement scale.
    once you find the hot, connect this to the center terminal of a spdt switch, the loads go on the opposite ends.
    • scorrpio
      • Jul 2006
      • 9
      Back in Russia, wiring was pretty rough. Everything 2 wire, 220V hot and a neutral, no ground. No color coding either (usually).
      Just figure out which of the 3 wires is hot. Should be easy - whichever short wire touched to the long turns on the fan is the hot. What you need is some way to connect the hot to one side of BOTH buttons on the switch - most likely using a short piece of wire. Then, you connect the other two wires on the other sides of those buttons, and you are good to go.
