I currently have a kitchen light that is controlled by a 3-way swith. I installed a new ceiling fan that has a remote control. The remote is designed to be mounted into the switch box, but there is currently a switch there. I would like to just remove one of the 3 way switches so I can install the remote in it's place.
I am not sure what I need to do with the wires when I remove the switch. In the switch I want to remove there is one white and one black wire going into either side on the top of the switch and one red wire in the bottom. Can I just tie the wires and if so, which do I tie.
Thanks for any help!
Kevin
Kevin
