I have a question....
Ok, my dad has what we call a "pump shed" at his house. It's a shed that was built over the top of a big cement pit. Inside of this big cement pit is a pressure tank for the well. (He has well water)
When we tore down the old shed and built the new one over the existing cement pit, we discussed installing a lamp inside the shed, and maybe even a receptacle in it. However, we were wondering if maybe we could tap off of one of the lines that runs the presure tank to power our light/receptacle? Also the same 240 volts that runs the pressure tank runs the well.
So would it be safe and possible to use one of the lines for this? Which hot lead should we use.....the red or the black?
Thanx.
Thanx.
