I have a half bath with a ceiling light and no outlet, so I purchased a "Single Pole Switch & Single Receptacle" conbination device (Pass & Seymour 691-I) at Lowe's. Of course, it had the wrong instruction sheet enclosed.
The switch is above the outlet, with two screws on each side, plus a ground screw.
Removing the old switch, I found a black wire which I attached to the lower right screw labeled "hot", and a white wire which I tried on each of the other three screws in turn with no results until I attached it to the upper left screw. Now the switch turns my light on and off, but there is no power to the outlet. How can I get the outlet working? I would prefer it to be "live" at all times, but I could live with it only working when the light is on. A wiring diagram for this would be wonderful. The manufacturer's web site failed me. Thanks for any help.
