I Know nothing about home repairs. I can paint a few walls, spackle but nothing else. I learned how to bleed the furnace last winter only because it was freezing out and didn't want to wait for my hubby to come home after work and do it. It was spooky in there!
Seriously. We have a circuit breaker that runs to our well house/pump. We have been living in this house from new for a good 6 years now. The circuit breaker is tripping. There is nothing on in the house running nor does the well house have anything on including the pump when this happens. Today it has tripped several times, not running any water mind you, nice and quiet in the house and pop, it is now tripping and won't stay on.
My husband tells me it is just a bad breaker, they go bad sometimes and just need to be replaced. We have fuses out in the well house that the pump operates through then of course our breaker in the home. We do turn that breaker on and off a lot when we have power outages or when away so our pump doesn't turn on and run if we would have a leak or something to that fact. We also have a safety switch on the pump power line itself incase it's running and not drawing water so it doesn't burn out.
Big question now that I have a novel here, is my husband right? Can breakers just go bad at times do to switching them on and off a lot. All the other breakers are fine. I don't want to doubt my husband but we really can't afford an electrician right now, he has changed breakers and fuses before. He even told me we couldn't put a higher breaker on because it wouldn't serve the purpose it was meant for so he must know something.
Thanks in advance for any help, sorry if this is a really stupid question.
