I have received a very nice dishwasher from a past tenant from Korea. It is a 240 system with a two prong round plug. I also received a step up transformer designed to plug into our regular outlet and the Korean unit plugs into it. It has a 20 amp fused switch. It runs fine for a while but at certain points it trips the house breaker. It heats the water so I guess it uses more than 15 amps during these cycles. I have considered trying to disconnect the element and rely on the hot water temp. from the tap. Can I get a smaller heater coil in Canada for it.
I also wondered if I could build an adapter to plug into the oven outlet. It already has 220 and sufficient amperage. Ours has two hot lines a ground and a neutral. Since the Korean 220 is different from here how would I hook it up and is it safe to do so. Also does anyone know where I could get a korean outlet in Vancouver BC area to use for this project if I go that route.
