I'm installing a series of outlets in my basement and I have a couple of questions. I have an older breaker box 1960 in the box there are two strips of breakers 10 or so on each side. On the right side there is a hot (black wire) on the left right side of the breaker is a neutral (white wire). On the right strip on beakers there are all hot wires going to them with the neutral wire running to the top of the box, why is that?
I thought the top was for ground wires? Should I run the ground when installing the out lets?
