cold weather outage
  • fixintoloseit
    • May 2008
    cold weather outage
    there are three light switches along one south facing wall in our kitchen that will not switch on in cold weather, even temps as high as 60F. they work all summer ! the disposal switch which is right next to one of the light switches, works year round, and so do the outlets along that wall. ideas? thanks.
    check the wiring into the switch I.E. quick wire terminals.
    • 596
      • Jul 2007
      • 90
      Just curious......what lights do these switches control? Some fluorescent lamps will not start in the cold. Could they be controlling lamps which are outdoors? Or lamps which have a ballast located maybe in a cold attic? Just a thought.
        flourescents should fire in 60 degree weather
        • fixintoloseit
          • May 2008
          thank you so much, we will do so.
          • fixintoloseit
            • May 2008
            re:coldweatheroutage
            all of the lights are incandescents. one is backyard patio light, the others are kitchen, over the sink & over the countertop.
            thanks to all
              check the switches. if they are the quiet type they have a small mercury pellet inside that has to be mounted correctly not upside down. at the top of the yoke is printed TOP
