Ok Tom, I got another electrical job from a neighbor. Right now they have a 60A fuse box, the lines from the electric company look pretty small too. We are hoping they will handle 100A service. They are not pulling a permit or having it inspected even though I recommended it. Their electric meter is actually in the basement right next to the panel. Their weathercap and conduit are mounted under the soffit (does not go through the attic). It has a 90* bend and then runs down the exterior wall and into the basement.
This is what I am planning on doing.
Install new lines 4 AWG CU and weathercap to the line side of the meter and from the load side to the panel.
Replace their old 60A fuse box with a 100A breaker panel.
I will bond their water meter but probably won't drive a ground rod.
Install a 60A breaker sub panel in the garage. To do this I can just use a double pole 60A breaker using 6-3 with ground, correct? I know the sub panel must have an isolated neutral and ground will be bonded to the enclosure.
Thanks
Dan
Thanks
Dan
