Hey all,
I have an odd situation in my garage.
I have 1 switch on both side of the garage turning the lights on/off.
One of the switches is old and it busted off… so I went and bought a new 3-way switch.
Installed the switch and everything was working properly for a week… then at 4 am in the morning all the lights in the garage turned on. So I got up and flipped the switch, they still stayed on… so I went to the other switch and flipped it, and again, it stays on!
So no I’ve got constant power going to the lights… I have to pull the fuse to turn them off.
I took out the new switch and tested it with my DMM, it works fine… so I wired it back up and test the V, and I’m getting about 14V on both sides of the switch! I test the continuity, one side of the switch is constant, and the other is speratic beeping… so I flip the switch and test again… same thing, one sides constant and the other is speratic.
Should I assume there is a short somewhere in this old Wiring? And if so, how did it all of a sudden happen while the lights were OFF and a week after it’s been running fine?
Thanks all for the help!
