One outlet on a circuit does not have power. The outlet was previously working. All other outlets on the circuit have power. I tested the wires after removing the outlet and no voltage. How do I find the problem?
No power to outlet
You need to find out where the power comes from that feeds that outlet. Its most likely a outlet on either side of that outlet. Just make sure you turn off the breaker before hand. If thats the last supple on that line then a wire is not makeing contact in the outlet before it. If you find other outlets passed that outlet thats working them replace the bad outlet.
Please, kill the power first then use your ohm meter to test the circuit. If no ohm meter, replace the outlet. -
Check for wires stuck in the back of the receptacle. This is called backstabbing and is likely the culprit.
The problem will be in the last working, or the first non-working receptacle.Comment
Found the Problem
Talking to you about this reminded me I replaced a switched on the same circuit recently. Sure enough, I removed the outlet cover and found a loose wire. Now I just have to figure out how to wire that all together properly.
Thanks for you help.Comment
The breaker keeps tripping but only when I run the microwave AND the toaster at the same time, like clockwork every time. Is my house wiring dying? It's...
Channel: Electrical
