Adding a light to a 3 way switch
  • jean
    • Sep 2002
    • 24
    In my stairway, there is a light at the top that is controlled by a switch at both the top and bottom of the stairs. I have added a recessed light at the bottom of the stairs.
    But I can't figure out how to wire it in. I would like it to be controlled with the light at the top of the stairs, but I have no access inside the walls to get a wire through to the top light.
    The only wire that runs to the bottom switch is three wires, connected to a three way switch.
    How can I wire in this new light without being able to get to the upper switch or the upper light?
    Thanks in advance for any suggestions! This one has me stumped!
  • irregularjoe
    • Nov 2003
    • 176
    why don't you have access to the walls?
    Is there an attic?
    You need to tap into either the top swich or the light. The 3 wire bottom switch is not a full circuit.
    • jean
      • Sep 2002
      • 24
      The walls of the stairway are finished, and the stairs go down to a finished basement. The basement was finished using sheetrock, and provides no access to the area.
      Is there usually some way to get through a level of a house? Maybe I could run a some romex beside a pipe that goes through all floors? Haven't found one yet that would work.
