Is Ground wiring in a house expensive?
  • mossrisjhons
    • May 2009
    • 9
    Well, I have brought a new house but there is some ground wiring which needs to be done in it.
    SO, how much it costs?
    the ground system in a house should already be there at the service entrance. any grounding on the branch circuits should already be there as part of the cable assembly, (i.e. - romex or bx) unless your wiring is knob and tube, running a seperate ground to these boxes and devices is NOT permitted.
    • mariyasmth11
      • May 2009
      • 9
      Well, that depends upon the area on which you need ground wiring.
      By the way ya its a bit expensive than normal wiring.
      So, don't worry just get it done.
      • Speedy Petey
        • Nov 2006
        • 214
        What is "normal wiring"? And how do we know what the OP is even talking about?
        Running an equipment ground for circuits?
        Installing a grounding electrode system? Ground rod? Ground/bond water pipes?
        From the original post there is nothing to suggest without more info.
