We've been redoing our kitchen. The color schemes and the age of the house come into play that have made this more challenging that what it should be. Here's the deal ....
On the existing kitchen wall there is a box that has two receptacles that are both 15 AMP but run on a 20 amp circuit (wires are all 12 guage I checked that), one receptacle is a regular 2 outlet 15A and the other is a 5224-2A (double switches sideways). We wanted to do all our receptacles and switches in black to go with our brushed nickel wallplates to match a bunch of esthetics the wife has going on. The Existing 5224-2A is white and controls the light above the sink and the garbage disposal. One of the issues is that Leviton and/or other manufacturers do not sell a black 5224-2, they only sell brown, ivory and white. I know I can get rocker switches but with the age of the home and the other receptacles we wanted standard type switches for looks.
Okay finally the question with what I have to work with...
Can I get 2 LE-5225's in black and and have each switch on a separate receptacle in the same junction box (I want both outlets on bottom hot at all time on each receptacle). The Other issue is the 5225 combo's are 20 Amp.
Will this work with the existing wiring (and i figure I might have to run a split somewhere in the junction box) and is this possible to use this hardware (5225-20A) and is it safe/compliant, since there are 2 other 15 amp receptacles on this same parallel circuit run.
Thanks in advance - I can't believe they sell the 5224-2's in that ugly brown but only sell black in rocker style switches (guess they're is still trying to peddle off that ugly brown stuff overstock from the 70's).
Hope this makes sense. Thanks in advance.
