I plan on removing my ceiling light in my bath and installing an exhaust fan/light combo. I can use the same wiring correct, and it will wire up basically the same way? I plan for the fan to come on whenever the light is on. The exhaust tube will go up into my attic and my soffit is about 3ft away. Would that be the best place to exhaust it? And should I run it across the floor or elevate it. Flexible or rigid duct? What type of outlet hole in the soffit to prevent anything from getting in through it. My attic is unfinished and unheated. Should I have any freeze worries in the duct or insulate it. My attic gets cold but not extremely cold.
Sorry about the winded post.
Thanks!
Thanks!
