Hello,
I am replacing an existing outlet, non GFCI, to a combination outlet. I have searched the forums here and I have everything almost working except one thing. I can't seem to get the switch on the 5225 to control my light above my sink. Either it's on all the time or it doesn't come on at all.
I have three wires coming in from the breaker box, black, white, ground. That comes into my GFCI plug. I'm not sure what I'm missing after that. Going from the GFCI to a regular outlet works fine, but I'd like the combination switch so I can turn the light on and off and leave the outlet on the bottom of the combination switch have constant power.
The 5225 has a gold screw and a silver screw on one side. Two black screws and the ground on the other. I took it apart trying to figure out what I was missing and didn't write down what I originally did.
So I just have the GFCI plugged in right now, so I have at least one outlet to use.
Thanks so much,
John
So I just have the GFCI plugged in right now, so I have at least one outlet to use.Thanks so much,
John
