installed two ceiling fans one has burned up my brother in law says that a rotary switch is only type that will work without burning them up. i installed them and used a slide type of speed control. based upon what i have read my control may not be rated for the amps required to control both fans. who is right?
ceiling fan speed control
any speed control when set up with a fan, the fan should be set at its highest speed. that way the remote speed control is controlling the whole winding instead of parts of it. the type of motor for the fan is called the PSC motor. Its an induction motor with a start winding and a capacitor in series with the winding. the capacitor gives the motor a kick to get it spinning.Comment
The breaker keeps tripping but only when I run the microwave AND the toaster at the same time, like clockwork every time. Is my house wiring dying? It's...
Channel: Electrical
