Advice on electrical panel changing
  • FatimaandAhmed
    • 343
    Hi!
    Need to know the details for upgrading a home's electrical panel from 100 amp to 200 amp service?
    Need a detailed answer please..
  • machinist
    Moderator
    • 386
    Hello!
    Before you begin, you’ll need to get the proper permits from your local building department. This ensures that all work meets local codes and safety standards. Once you have the permits, you’ll need to contact your utility company to schedule a power shutoff, as you’ll be working with live electrical wires.
    Next, choose a suitable 200 amp panel. Make sure it meets local code requirements and has enough circuit slots for your needs. When you're ready, turn off the power, disconnect the wires from your old 100 amp panel, and carefully remove it. Install the new panel in its place or a new location if necessary.
    Upgrading to a 200 amp panel often involves replacing the service entrance cable, which carries power from the meter to the panel, and possibly upgrading the meter socket to handle the increased capacity. Additionally, check that the grounding and bonding of the new panel comply with current codes. This typically involves connecting a grounding wire to a ground rod and ensuring the neutral and ground are properly bonded in the main panel.
    After installation, schedule an inspection with your local building department to ensure everything is up to code. Once the panel passes inspection, turn the power back on and test the circuits to make sure everything is working correctly.
    Remember, upgrading an electrical panel is a complex job and should ideally be handled by a licensed electrician to ensure it’s done safely and correctly. The cost can vary, including the price of the panel, labor, permits, and any additional materials. Considering future needs when selecting your panel, like additional circuit slots or smart technology features, can help ensure you’re prepared for any upcoming changes.
    I hope this explains everything in detail!​
    • FatimaandAhmed
      • 343
      It looks like it’s better to let a professional take care of this.
